Core drills
View the thread, titled "Core drills" which is posted in Plumbing Tools on UK Plumbers Forums.
Riley
Subscribed
Alright my plumbers from another mother
Know it’s been asked before but what core drills are people using. I need to bite the bullet.
Hello Shaun. You always know of the nicest gear. Think that’s a little outta my price range. Don’t mind something In the £400-700 mark
The thing is probably but I wouldn’t do that many also depends what your going through
if your doing a lot of 6” through hard stuff I would say no
Sorry can’t contribute, but are you back now Riley?
actually, tell a lie, I’ve used one at work - Makita - didn’t like it as it was like Bob Marley, kept jamming. Cores were crap as well.
I too have the makita 8406 and find it very good. Did 6” core for my kitchen extractor easy (mind you it was only block and render so cheating really).
Done loads of 127, 117, 65, 52, 38 holes in all sorts.
Mind you this time I never use this drill for anything else, strictly cores only, so it’s never been on hammer and it’s lasting really well.
@IND Nick
Depends on the power rating of the Makita doesnt it, they can vary enormously from 850w to 1400W and are priced accordingly. Whereas the Millwaukee has a high power rating as standard.
The Milwaukee is a DD2 - 160XE which says it is 1500W. The Makita is a 8406C which says 1400W.
So there's not much in it.
As said I have both and in my opinion, and the lads who work for me, the Milwaukee performs better. But both are good quality and will definitely do the job.
Blimey all those cores!! Why not just SDS with a chisel bit - actually last time I did similar job it required the 15kg breaker - but breaker must be much quicker than cores I would of thought?
Just trying to be precise. The concrete was 6 to 8 inches thick. Used the core method over a 1700 x 800 area. Sorted the waste, small pour of self leveller and then tile adhesive to stick the former down.
Tried my breaker but just not precise enough.
Reply to the thread, titled "Core drills" which is posted in Plumbing Tools on Plumbers Forums.
Riley,
WC1,
