Mar 17, 2021
Uk
DIY or Homeowner
Hello!! I’m designing a shower room at home, the current lay out has a corner toilet. Would I have to replace the toilet with another corner one of is it an easy fix?? I’m guessing something to do with pipe work. (I’m a mum not a plumber) any advice would be great!
Corner toilets are usually used when there isn't space to do anything else. If it's possible to fit a conventional pattern loo in your space then you're right, modifying the plumbing is likely to be a bit of a game.
Reactions: Aon1980
C
Boiler Advice Forum
Deleted member 120897
