View the thread, titled "Correct size of radiator for BTU calculations" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi I’ve done a BTU room calculator, going by the calculations I need a radiator 6407 BTU, and 1877 watts. I’ve found a radiator just over these calculations at 6581 but in the description delta T65 is 6581. Delta T50 is 4695. Delta T30 is 2433. I have a recently fitted combi boiler. Would this radiator be fine for my room? Or do I need the T50 readings to be the same as my room calculation? Thanks for any help 👍🏻
Needs to be dt34 or dt29
So dt50 size would be 10.5k btu
So would the one above not be sufficient for my room?
If I calculate my room at 6407, what reading of radiator should I be looking to buy?
I’m pretty confused as tried a few different calculators and they’ve all gave me totally different readings ranging from 3000 to 6000. Thanks
Reply to the thread, titled "Correct size of radiator for BTU calculations" which is posted in DIY Plumbing Advice on Plumbers Forums.
