cost of quote for replace of old radiators
View the thread, titled "cost of quote for replace of old radiators" which is posted in UK Plumbers Forums on UK Plumbers Forums.
F
flozz
cost of quote for replace of old radiators for newer ones like below
TOTAL 6 RADITORS THANKS
depends, on size of rads, type of system, how much pipework is involved need more info.
are the existing rads the same size ?
what type of system is it on ?
have they got trv's fitted do they need replacing ?
trv's will use the one already on old pipework so wont be replacing trv's the olds ones are fine
rads all same size
combi boiler system
where are you in the country as rates vary so much.
plus you''ll be hard to find a descent plumber that will quote without seeing the job.
many won't fit what someone else has brought, they like to supply their own rads.
as for the locksheild valve i never fit new rads to old locksheild valves.
Definitely something that you would need to see in person before quoting. Changing a radiator can be a 5 minute job if it all goes well but if you get one with the tails seized into the radiator, dodgy wall behind the rad etc. you can be looking at 4 hours.
Mike
Reply to the thread, titled "cost of quote for replace of old radiators" which is posted in UK Plumbers Forums on Plumbers Forums.
flozz,
Mike Jackson,
