DoItRight
Hello & thanks for taking the time to read & reply:
I'm new to this so apologies if my terminology isn't quite right
My old vented cylinder is about to give up the ghost so I'm wondering if this is the opportunity to swap to an unvented system, so that I can get rid of the tank in the loft and improve the pressure throughout the house.
We have a blue pipe from the mains, and 6 of the 8 pipes throughout the house are 25mm (no idea which are CH and which are tap water) but my luck the two 15mm are the latter
I believe/hope the potterton Promax HE is up to the job (10 years old condensing 15kW heating only boiler)
The main problem, I believe, is that we have an extraordinary number of 90 degree elbows throughout the house (semi) which probably explains why the hot water flows into the bath at about half the rate of the cold water.
So would we actually get the full benefit in switching to mains pressure, or would we also need to "improve" the plumbing?
As a side note I'll also be switching all the rads to TRV's all hooked up to a home automation system.
Thanks for any thoughts / opinions / advice
P.S. There's nothing wrong with the boiler which is why i'm not really considering switching to a Combi (which would face some of the same issues)
