WaterTight
Subscribed
Apr 15, 2009
5,433
2,220
113
1. Potential job. Cracked shower tray. 3 of 4 sides of shower have tiled walls on top of them. The fourth side has the screen door on top. You with me? So potentially quite jammed "in there." How much of a mission would it be to replace this? I imagine if I broke / cut the tray up in situ and yanked the bits out I'd get it out after (worst case scenario...) an hour or so. Squeezing the new one in though... I've no idea how hard this might be. I said they'd almost certainly lose at least a row of tiles.
I've never personally, solo, fitted a shower tray. Worked alongside a plumber doing so twice - but not in a particularly hands on way. Done 200 or so other plumbing jobs, few suites, lots of taps, toilets, rads etc... So, firstly, is this a nightmare type of job - any tips? And secondly, should I not attempt until I've at least fitted one from scratch in a less tight and tough situation?
2. Slotted basin wastes. What is the deal? Are you really meant to silicone every bit of it? Obviously silicone under rim at top. Then many suggest between doing so also between washer and basin underneath. But for the last 2 or 3 I did I then find unless I silicone around the gap between the nut and threaded tail at the bottom that leaks too. Presumably some water going down the waste goes out of the overflow hole in the waste and runs down. It just seems so bodge-like. Unless I'm missing something? I don't over-tighten. Just hand-tight and then a 1/4 turn tweak.
Hi watertight. You have pretty much answered your own questions. I can never get the tray out or new one in without taking off the bottom row of tiles. And the door off, as this will be mastiked to bottom tile and not forgeting the bottom horizontal bar.
Slotted waste has to mastiked up around bottom nut like you said.
If enough thread on the bottom of a slotted waste you could fit a 'Basin Mate', no need for mastic then. Only a couple of quid from merchants.
hello my name is gurmeet gulati i live in kingston. i have just finished level 2 for plumbing and going to start level 3 soon . i was looking for someone to work with so i can get apprentaonship and get work experience . it would be great if someone would get in contact with me and help me out . thanxz for your time hope to hear from you soon
