Jul 30, 2023
71
London
Other Tradesman
Hello,
One of my nightmares scenarios is cutting am copper pipes in tight spaces where you can’t get a pipe cutter in there.
I eventually got a pipe cutter to cut the pipe but only after becoming a contortionist.
My initial go using a multi tool failed miserably as the cut wasn’t square.
Can anyone suggest how best to cut pipes when space is at a premium.
Cheers
That’s sound advise.
Can you recommend a good blade.
As a side note. I tried using an end feed as a guide but it didn’t make much difference. I must admit, I did push and perhaps the multi material blade wasn’t the perfect selection.
Bi metal one eg
Depending on your multi tool
