DAB Esybox and break tank
View the thread, titled "DAB Esybox and break tank" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Morning. Looking at installing a DAB Esybox however space at a premium. Thinking of installing a break tank in the loft (above first floor) rather than going for the combined pump and tank unit. This is replacing a vented system so pipe work goes up there already. Is there any reason I shouldn’t do this? Read about bacteria growth in tanks but guess that’s a risk wherever installed?
I should add the unvented hot water cylinder and pump to be located on the ground floor.
Also, anyone installed an Esybox pump outside?
Need to install a couple of tanks in the loft as you need around 400-500 stored depending of your water mains flow and pressure etc but no other than that it’s fine
The tanks need to have a lid and comply with water bylaw 30
There are many tanks in lofts around the uk
Doesn’t matter where the unvented is
Reply to the thread, titled "DAB Esybox and break tank" which is posted in UK Plumbers Forums on Plumbers Forums.
Csanders578,
ShaunCorbs,
