View the thread, titled "danfloss 3 port valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
ray91
hi, had plumber to change 3 port valve, old one seized. now hot water and heating on together, valve doesn't turn from mid position. suspect wiring incorrect. Old danfloss actuator wiring yellow, blue, orange, white, green. new danfloss actuator wiring blue, brown/white, orange, grey. Does anyone know which wires go to which please. Thanks, Ray
Get the plumber back to sort it out and don't let him / her leave till you're both satisfied it works correctly
wish it were that easy. he's already spent 3 hours, that's as much as i can afford, hence the post. he changed the valve body so i can turn it manualy, i supose that's something. thanks for the advise anyway, much appreciated.
hi
If you have paid any rectification should be at there expense
You shouldn't have to pay for him to put the wiring right!
Sounds like he's changed a momo valve for a spring return valve & hasn't adapted the wiring.
Get him back to sort it out
Done one last week. ,,Uncle,, changed it and wiring was appalling!
Brown/white connect to heating call from room stat.
Orange connects to terminal linked to pump & boiler.
Grey connect to hot water off from programmer.
Hi is the yellow, a yellow and green?
If it is, then it is an earth connection.
Also do you know if there are 3 outputs from the clock or two outputs?
Two outputs = Ch/on and Hw on.
Three outputs= Ch/on and Hw on/ and Hw off.:tounge_smile:
Reply to the thread, titled "danfloss 3 port valve" which is posted in UK Plumbers Forums on Plumbers Forums.
