View the thread, titled "Delay timer for heating pump" which is posted in Central Heating Forum on UK Plumbers Forums.
The first three are the only numbers that interest us just now.
"Saturation Temperature" is the temperature of the water.
"Specific Enthalpy of Water" is the energy content of the water. (Sensible heat)
"Specific Enthalpy of Evaporation" is the energy required to turn 1 kg of water into 1 kg of steam at the same temperature. (Latent Heat)
They all come from.....
If you want me to explain it further, fine.
I will get my thermodynamics book out again. What is the website you found that calculator on?
Something like this is what you need
This was what I wanted years ago to give my own bathroom fan an over-ride function. Unfortunately Rapid Electronics had nothing of this sort and I didn't know where to look. I suspect this plus a separate non-timer fan would prove more reliable than rely on the cheap internal circuit of an all-in model, and at least when one unit breaks you don't need to change the whole lot. So thanks, Shaun. Next time...
So John, I've taken on board what you've said. IF I have a 200 litre cylinder at roughly 110°c how much of that volume flashes to steam if the pressure drops below saturation point?
If the pressure/temperature falls from 0.42bar&110C to 0.0bar&100C then the % of flash steam (using steam tables, above) will be, ((460.86-418.55)/2256.47)*100, 1.88%. So 200 litres will flash off 200*1.88%, 3.76 litres.
Suppose should/must mention the qualities of steam for heating purposes where it is almost universally used in plants/factories normally at 8 bar which gives a temperature of 175.4C necessary for some processes.
As you are aware steam gives up its heat at constant temperature (isothermally) so if you compare a heating requirement of say 20Kw with steam vs hot water then only steam at a rate of 0.59 kgs/min (~0.6 LPM) is required as it gives up 2030.25 Kj/hr/kg (0.564 kw), if water heating is used then ~ 29 LPM at a deltaT of 10C will be required. Also steam heating reacts very rapidly to changing heating demands as its controlled on pressure, hence lower/higher steam temperatures instantly , the coil outlet is normally fitted with a float type steam trap which (traps the steam) will only pass water and ensures all the steam's latent heat is extracted.
Yes I can wrap my head around this but will read over what you've mentioned above a few times. I thought what I knew above was enough, clearly I was wrong 👍
Hi everyone,
got to the bottom of the wiring for this relay should anyone else do one.
perm live goes to A1 with link to 15
neutral = A2
switch live to S
pump feed on 18
thanks for everyones help
Excellent - I'll report back once I've wired the new stat into circuit next week!
Thanks, Graham
I've wired the capillary stat in now, and as predicted it seems to be doing the trick just pumping round the circuit formed by the ABV.
I've put the extra stat inside the boiler cabinet and brought an extra permanent live across from the main junction box to power the pump bypass. In fact I haven't actually wired it in permanently yet as it occurred to me that I now needed to isolate both my new permanent live to the boiler as well as the existing switched live. I'm using a three pole isolator switch for this (the sort that are used for timed fans) in place of the current switched, fused spur. The whole installation is already fused elsewhere in the room, so I don't think that losing this fuse local to the boiler is a problem - unless you advise otherwise! I could put a simple fused spur outlet in as well if thought to be needed.
Thanks again for all your help, and the interesting diversion about steam thermodynamics - I haven't seen some of those terms since I was studying Physics at school which was a very long time ago 🙂
Graham
So the new stat wired into keeping the pump circulating after boiler shut down is pumping around that shirt 7m section of pipe and keeping the limit stat from tripping? If so that's handy to know that short length of run is enough for future reference.
Is the whole central heating circuit on its own 5 amp fuse and all wires come off that incoming supply?
Yes. Actually, I have a feeling that it's also on its own circuit from the consumer unit (probably with a 15A MCB but I'm not at home so would have to check that) as well as the local switched spur which powers all the heating circuitry.
It could be on its own circuit and more often than not people will spur off a ring main. If its got a switched fused spur then it's fine and will protect the system componentsin the event of a problem. Oil should be on 5 amps but could be a 3 amp fuse in place.
I wouldn't have been surprised if it was spurred off the ring, but I don't think it is. I'll check the fuse rating in the fused spur tonight. I presume that 5A for oil rather than 3A is due to the starting current of the burner motor.
Thanks, Graham
Thanks, Graham
The inrush current of the motor will be more than steady state yes. If its got a 3 amp in already and it's been fine until now then it should be fine, after all a 3 amp fuse should melt before a 5 amp in the event of a problem. I was just told on my OFTEC courses oil should always be 5 amp. If you really wanted to do the maths you could work out what current was being pulled but I've never bothered.
Graham
What is the stat setting and does it cut in/out a number of times before the boiler temperature stabilizes?
Hi everyone,
neutral = A2
switch live to S
pump feed on 18
that’s an odd setup how did you figure it out ?
spoke to couple of electricians and they both said they thought perm L should be on A1, then found these on geya website:
tested it on leaving sat morning and all seemed good & customer not contacted me since so seems to have resolved the issues
The stat is set to about 90C (I'll explain the about in a bit) - I couldn't decide whether it was better to have it come on sooner and "waste" electric running the pump, but nip the overheat in the bud so to speak, or set it high so the pump only comes on when there's a danger of the overheat trip going off. So 90 was a bit of a compromise for now.
My criteria for success was that the overheat trip didn't trip and it hasn't so far so that seems to be OK.
I can't totally answer your question as I haven't (yet) studied it closely. What seems to happen is that the worst time is first thing in the day when the house is cold and the boiler is firing for a long time to get everywhere warm. That's when I have seen/heard the pump running from my new thermostat. What then happens is that after a while the room stat calls for heat, which then opens the motorised valve and that obviously cools the boiler down much quicker until it fires again.
I wanted a stat that was in an enclosure, and also one that had a range over 110 so that it wouldn't suffer if the boiler got so hot that the overheat trip went. So I got this one from BES: Capillary Control Thermostat - https://www.bes.co.uk/capillary-control-thermostat-9781/ which has a range of 50 to 300C which is why I said the setting was about 90! This was the best one I could find - I expect you'll now point me to a much better one 🙂
Once I've studied how it's working I'll post here. I might also be asking you why my room stat appears to be short cycling the boiler - but not now...
Graham
Looks a pretty good little control thermostat. You say the roomstat appears to be short cycling your boiler? I'd it only happening during a demand for heating?
Reply to the thread, titled "Delay timer for heating pump" which is posted in Central Heating Forum on Plumbers Forums.
Thread starter
plumb_know
Joined
Location
Maidstone, kent
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
plumb_know,
John.g,
