View the thread, titled "Desperate for advice please - new hot water tank" which is posted in Bathroom Advice on UK Plumbers Forums.
U
Unregistered
I have just had my hot water tank changed as the old one kept causing the electrics to trip out due to the build up of lime scale and silt over a 50 year period and it had also started leaking. The hot water tank is in my airing cupboard next door to the bathroom in a position slightly higher than the bath taps so the flow previously was never that great but acceptable. I live in an ex council flat and cannot move the tank to an alternative position. I don't have a loft or heating system other than under floor heating and a few electric radiators.
The cold tap receives mains pressure water directly, so there is no problem with that, while the hot tap receives water under gravity from the tank. When the water in the tank is completely cold it runs at an acceptable level to fill the bath, however when the water is hot it only trickles very slightly through the tap.
After installation the plumber thoroughly flushed the whole system out so there was no air present and when he connected the tank fill water main directly to the hot tap pipework to test for blockages there was no pressure loss so he (and we) are at a loss as to why the hot water will not flow through.
How can the same water from a tank flowing under gravity operate perfectly well when the water is cold but not when the water is hot when it takes exactly the same route from the incoming water main?
Any advice or help would be greatly appreciated. Thank you.
Are they separate hot and cold taps, or is it a mixer?
Does the problem occur at both bath and basin, or just one of them?
Are there any thermostatic controls (for instance a thermostatic anti-scald device). Such a device might look a bit like the picture underneath, and should be close to the affected outlet.
Thank you for your response. They are separate taps not mixers. The problem is with both bath and basin. No thermostatic controls just the element setting on the base.
Reply to the thread, titled "Desperate for advice please - new hot water tank" which is posted in Bathroom Advice on Electricians Forums.
