ID'd a boiler today and capped it off with the customer's permission. Leaking primary HEX on a condensing boiler. Large leak of CH water and condensate from the burner box out into the airbox on a Potterton Promax HE heat only boiler on an open vented system.
Reason for ID was the leak was already working nicely on corroding the gas pipe between the gas valve and the fan. Case was also starting to corrode.
My view was I didn't want to walk away without capping it off or getting Transco to do it as if that pipe corroded through the boiler could go bang.
Right or wrong call?
