View the thread, titled "Digital manometer or water is best ?" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
Water for TT and Antonio digital for everything else. Electronic is essential for fan pressures as you get a more accurate readings.
Upvote 0
water for soundness testing or TT as its now been renamed,water u gauges never need calibrating,and they never lie,though if you put dark red food dye in them and turn the ECV on to fast they make a pretty pattern on the wall
Upvote 0
Testo 510 sits neatly in my servicing case so I use that, can take everything in the property for servicing etc in one go.
Upvote 0
Prefer digi here, why people say water for tightness I have no idea. Digital does the job just as well, that said so does a water gauge so each to their own. The reason I like digital are because they are more precise for fan pressures etc, smaller, don't freeze in winter and if they don't need topping up with water every now and then. Also if you do LPG you don't need to store it on the roof rack :biggrin5:
Upvote 0
I don't need to store my Regin premier gauge on the roof rack and it does up to 45 mbar. My J gauge will do up to 110 mbar which allows me to test new installations on boats.
Digital is fine for burner pressures etc. but I just don't trust it for tightness testing. How do I know that the digital gauge hasn't malfunctioned? Plus I don't have to get my U gauge recallibrated every year.
Upvote 0
Sounds like it was to early for a spot of light humour! I trust my digital gauge as much as my flue analyser and the consequences of malfunction are much the same. As I said, each to their own. Everyone's a winner and we all get a badge for good behaviour.
Upvote 0
Good old water for me,with a bit of blackcurrent cordial in works a treat..
Plus i can sleep cause i seen it wid my own eyes.
Upvote 0
If you use a digital always keep a u gauge in the van as a back up. There will come a time when you doubt your digital.
Btw you shouldn't add anything to your gauge other than water or manometer fluid as colourings, antifreeze, juice etc changes the specific gravity of the water and will alter your readings.
If you do, a 4mb drop may actually be a 5mb.
Upvote 0
I have both but only rely on water for testing for tightness etc. I have always thought if you don't believe your meter why have it in the van
Upvote 0
Water all day tried a digital didnt trust it so thought whats the point in that. Been using for a long while regin premier couldnt be with out now!
Upvote 0
Reply to the thread, titled "Digital manometer or water is best ?" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
