Digitron APM140 Differential Manometer - Out of range issue
View the thread, titled "Digitron APM140 Differential Manometer - Out of range issue" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, I wonder if anyone here can help me in resolving this issue.
The meter I have stops at 19mbar with 'out of range' message and I cannot use it for other pressure checks.
The instruction manual is not helpful. I contacted Digitron but they are not replying. The meter range is upto 130mb and I guess I pressed some button and it locked to 19mb.
Any help will be greatly appreciated. Thank you
It sounds like your meter might be in a locked mode or has a calibration issue perhaps? Try resetting it to factory settings - you can look for a reset button or option in the menu. If that doesn't work, check if there's a specific combination of buttons to unlock or recalibrate it.
Thank you for your reply The meter has range from 0 to 130 mbar. I accidently locked it to 'out of range' mode and the instruction manual has no information how to take it out from this mode.
As above, A/R
Reply to the thread, titled "Digitron APM140 Differential Manometer - Out of range issue" which is posted in UK Plumbers Forums on Plumbers Forums.
Hitech,
snowhead,
