I want to cap off the supply to my bath taps before removing the bath itself.
Would I do this with a few Polyplumb stop ends? If so, is there an obvious point on each set of pipes that I should disconnect and add the stop end too, or will any work?
(I'm only an amateur DIYer, but to me it looks like:
Thank you in advance!
- The hot is on Polyplumb plastic connectors with copper pipe and has it's own shut-off valve
- Meanwhile, the cold is on a flexitail and connects to a very rusted nut
- The gauge of the pipes appear to be different too. The hot appears to be on a wider pipe than the cold)
