View the thread, titled "Distinct lack of hot water from any tap!" which is posted in Bathroom Advice on UK Plumbers Forums.
Hello all you happy plumbers, firstly a hello and friendly wave.
I arrive at the forum after pulling hair and much gnashing of teeth due to my lack of hot water!
I, over the summer installed a couple of rads, bathroom and living room (vertical job), I had a fernox tf1 installed and new grunflos pump..so far so good.
The last week I've not been getting any hot water from any tap. Except if I run the immersion and heat the cylinder, so I can get by.
I did some research (Google/ You tube) and the evidence pointed to broken motorised valve (2 port).
I replaced that easily enough but the problem still persists. :angry_smile:
Layout.jpg It's a pressurised system, heating is OK. I now suspect big lot of air in system?
Any ideas via the collective mind of plumbers.
Fingers crossed
Greame
Reply to the thread, titled "Distinct lack of hot water from any tap!" which is posted in Bathroom Advice on Plumbers Forums.
