DIY advice - saddle clips
View the thread, titled "DIY advice - saddle clips" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi All,
Easy (and probably stupid) question. I have to run the pipes for a rad from above on the surface.
I'm intending to run chrome pipes down behind the radiator and into some right angle valves to hide most of the pipework.
Is it ok to use saddle clips to keep the pipes as close to the wall as possible so i can use the shallower rad bracket?
Hi All,
Yes, I don’t see why not. Are you thinking the chrome ones?
Chrome pipes actually catch your vision more and are rarely better looking than just using bare copper pipes or casing them in my opinion. Only good in bathrooms for short pipes to towel rails etc
Clipping pipes to wall with saddle clips makes decorating impossible.
Best to install pipes to side of radiator (preferably at corner of wall) using ordinary plastic clips or casings if you prefer.
Soldering is not easy on chrome pipe as chrome has to be removed.
If you are using compression fittings it will look a bodge
Agree with Best, copper pipes in corner of room (box in ply/mdf and decorate to make them disappear), or another favourite is to drop alongside the window (such that pipes are hidden behind curtain whether they are open or closed.)
At home simply have clipped copper painted the same as the walls, never look at it and if any visitors are bored enough to start looking round I’d feel if failed as a host.
Agree use plain copper and either home made or plastic box or even leave them bare and behind the curtains. Make sure though that this is acceptable to her that must be obeyed - that's the biggest hurdle - plumblings a doddle!
Pretty much everything in my Dad's house is copper on the surface like that, clipped to skirting boards and painted same colour as walls/boards where appropriate, very few boxings, a pleasure to work on the system. I grew up in that house and honestly only noticed the plumbing when I became an apprentice and got interested in all things pipework.
However, OP is obviously free to pipe up how they most prefer.
Reply to the thread, titled "DIY advice - saddle clips" which is posted in DIY Plumbing Advice on Plumbers Forums.
Simmozs,
Stigster,
