Guest viewing is limited
DIY heat engines for recovering waste heat.
View the thread, titled "DIY heat engines for recovering waste heat." which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Dolph1983
Hi, I'm running a project at the moment to build DIY heat engines and was hoping someone would have some ideas on sources of waste heat and applications for my machine?
Basically, a heat transfer fluid is supplied to the engine at about 80 degrees C, this fluid is heated by waste heat eg, solar heat or flue/exhaust gases. The engine works in a similar way to a steam engine (rankine cycle), however the water is replaced with refrigerant, so instead of generating steam it generates vapour at <100 degrees C.
The power cycle is called the 'Organic Rankine Cycle' and has been used for donkeys years in industry to recover and convert waste heat to electricity. I am trying to build a micro scale 1kWe unit for domestic use with biomass boilers and solar panels, but there are many other uses.
As a test bed i built a unit which can be piped into a gas boiler heating circuit to run it when the grid power goes down. So when power goes down the engine's battery supplies electricity to the gas boiler via a power inverter to get the boiler heated up. Then the boiler supplies some of its heat to the engine which generates enough electricity to sustain the boiler, recharge its battery and give a net output.
It's fairly easy to build and all the parts are available off the shelf, just needs some basic plumbing tools. I built it into an old washing machine housing!
Some photo's below show the test unit, it gives a shaft power of about 350 watts and a net electrical output of 190 watts. This one is just a baby, when it's fully grown it'll be giving a net output of 1kWe. The fully grown version will be housed in an old fridge freezer.
Stu.
Yeah pal, it would probably need a yearly maintenance interval, charge up then if needed, if it was seeing heavy use ie 24 hr's a day it may need more servicing. Which is fine when you can do it all yourself 😉 and the parts are cheap as chips.
I think there is a great future for thermal electrical power generation.
Here in Spain a vacuum tube can boil its contents in under 3 hours, and hot water is quite easy to store, it would be great to be able to convert the heat energy to electrical energy.
I am pleased to see the baxi eco gen it is a brave move by them I am sure other company's will soon follow in their foot steps.
There is a company in the U.S. which is quite interesting they are developing a heat and electric system for domestic use combining solar and a sterling generator
it is worth a look -- cool energy inc.
Ps. good luck with your project dolph1983
Tony Spain
Reply to the thread, titled "DIY heat engines for recovering waste heat." which is posted in DIY Plumbing Advice on Plumbers Forums.
Dolph1983,
cssolar,
