View the thread, titled "do i use pre commissioning cleaner?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
john1
thanks to info received on previous threads im having repiping done and new rads to bad system design.
if keeping old boiler do i still need to use a pre commissioning cleaner before adding a protector or will just a system refill/drain cold and hot do
with a protector added.
thanks for any info received in advance.
Yes,if you have had lot of pipework done you should use a commissioning cleaner,it helps flush out any acid flux left in pipework ,then flush through and add inhibitor/protector
A clean system is a 🙂🙂 system
Reply to the thread, titled "do i use pre commissioning cleaner?" which is posted in UK Plumbers Forums on Plumbers Forums.
