View the thread, titled "Domestic or Commercial?" which is posted in Industrial Plumbing Advice Forum on UK Plumbers Forums.
Steel looks a lot more professional 1" barrel bent and welded non of this threading nonsense!
No but a plant room with two Andrews water heaters in does! You can legally install a domestic boiler on a commercial gas carcass with a volume in excess of a zillion litres if there is a test point and isolation point down stream of your equipment and your working in a permitted location. I did a boiler swap in a laundry no to long ago. I called technical as I was sure I shouldn't but they said asking as from test point to boiler is within my scope jog on!
Keston c50 was branded as light commercial but lots and lots if them in houses on u16 with 28mm tube !
i phoned gas safe last year regarding working off an AECV with a test nipple etc .
they said its fine however i couldnt turn the AECV on to gas up appliance as it would then put me past my domestic licence due to volume of gas .So i could install ,and do a TT but then i would have to turn appliance off and get a commercial guy in to turn on AECV .
Not that it matters now as im commercial 🙂
Reply to the thread, titled "Domestic or Commercial?" which is posted in Industrial Plumbing Advice Forum on Plumbers Forums.
