View the thread, titled "Downstairs ch zone turns upstairs zone ch off and vice versa" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
M
moomin
New to the forum and first post! Thanks in advance for any assistance with problem. Apologies also it may be a long post to provide info! I am owner of house not plumber! There have been lots of problems, plumbers now dissolved company and trading standards involved, so please be kind about what should have been done, I am trying to sort out what best to do with what I have! Plumbers employed we took references from other customers, had contract etc but all to no avail! I am very happy to have other plumbers look at the problem however I want to have more knowledge in case the wool once again is tried to be pulled over my eyes (apologies to all good plumbers!)
Background. Large house, complete renovation, new ch and hw. Unvented system with Grant Oil condensing boiler. 2 ch zones plus hw zone.
House in excess of 150m2, building regs paperwork etc all in place prior to work started so plumbers aware Part L would need adhering to.
Plumbers installed single zone system, on questioning during the work, said was not neccessary. Building reg inspector picked it up during periodic inspection for new soil pipe install. Insisted 2 zones installed. There is a Heatmiser 4 zone timer in the boiler room. A hard wired heatmiser programmable room stat for the downstairs central heating, after the building reg inspection, plumbers said could not hard wire second prog room stat for upstairs zone so have a heatmiser 2 zone wireless prog room stat upstairs with the receiver in the boiler room.
So the problem is: HW works. Upstairs heating works, downstairs heating works however the 2 zones of ch will not work together. If one is working and the second zone is switched on, the one working switches off.
Apologies if I am not explaining the situation correctly. The 4 zone timer in the boiler room the zones on the timer do not correspond with the zones annotated on the port valves. Should they?
I have spoken to Heatmiser who initially said the problem would be not have dual port valves, but having checked the valves do look like dual port. Heatmiser also said the zones on the time do not need to correspond with the valves? Also there is not a need for a 4 zone time, plus 2 prog room stats.
Is there anything obviously wrong to your knowledgeable people? Could it be a wiring issue?
Once again thanks in advance and apologies for length of first post.
M.
Sounds like a wiring issue!
post up in the i'm looking for a plumber or heating engineer section here.
advantage with that is we give our time to help out people we don't know and fellow tradesmen
i would say all of us (bar pork chop) give much better customer service and are more willing to deal with issues!!
plus we have a reputation to uphold on here 😛
where are you based?
could you provide photos so we have a better idea?
Thank you so much for taking the time to read the long post and to reply. I already had provisionally booked the electrician to return this week to look at the wiring so I will report back when that happens. We have not moved into the property yet so not currently on site, however I will take pics when there tomorrow and post. Thanks again! I will also post in the suggested forum area.
Moomin
Just an update. It was wiring of the zones. All working now!
Many thanks for everyone's help, it is very much appreciated! Thank you for the time people gave reading and replying.
Moomin
Reply to the thread, titled "Downstairs ch zone turns upstairs zone ch off and vice versa" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
