Apr 13, 2015
67
Hello folks
I haven't had any experience working on radiators when it comes to replacing them on Unvented/sealed systems which include underfloor heating.
My question is more geared towards when draininh down, would I need to open the 3 port valve or two port valves to drain down a system? Does that drain down the underfloor heating, too?
Don't want any nasty surprises that's all when I think that'd I'd drain the heating side.
Thank you from a level 2 student
Martyn
Bear in mind the UFH pipes under the floor may well be fed from a manifold above the floor and, as such, gravity being what it is, will always have some water in them. But, as long as it stays put, it isn't usually an issue.
N
2K
UK Plumbers Forums
Novice needs help
N
