View the thread, titled "Drilling into a shower tray" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
T
tonytimms
I am installing a 1200 roller shower door in an alcove above a 1200 cast acrylic shower tray and the instructions say I need to drill 2 holes in the front top edge to fix a retainer clip for the side panel and a guide for the sliding door. This is making me nervous! Can I do this, and if so what kind of drill bit do I need and how will the screw attach to the tray, do I need to use a plastic lug or something because the instructions do not show this.
Regards
yes you can do this carefully. you will need a sharp hss drill, the instructions should tell you what size you need. tape the area where you need to drill with masking tape. measure carefully thinking "measure twice cut once" mark clearly on the tape. when you drill do it slowly so the drill doesn't slip. if only a certain depth is needed put some tape round the drill at that length. the screw should just screw into the tray in the holes you have drilled. oh and welcome to the forums.
Hi Steveb
Thanks for the info, looking at the screw it does seem to be a self tapper so I suppose this will connect ok with the base. Slightly less nervous now!
Regards
Reply to the thread, titled "Drilling into a shower tray" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
