View the thread, titled "Economy seven hot water tank connections" which is posted in Bathroom Advice on UK Plumbers Forums.
R
rankal
Hello, I am new to this forum. I am in the process of replacing my economy seven direct combination hot water cylinder. I understand that it should just be a case of replacing one with another, however the Newark tank that i have bought as a replacement has six female connections to the hot water storage part of the tank. I know that two are for my heating elements, one is for my hot water out and one is for my drainage tap, however i cannot find any reason for the remaining two connections. To make matters worse they are 25mm connections and i cannot find this size in any DIY shop. Any explanation and help would be much appreciated. Thanks.
I think there is a way of adding a coil to turn it into an indirect cylinder or to connect up to say a coal fire with back boiler for gravity heated hot water. Anyway just nip to the local plumbers merchant (take cylinder if necessary) and get a couple of blanks.
from the newark site, it looks like you may have an indirect economy 7 cyl as they have 6 openings: 2 for the coil, one for hw, one for cw feed and 2 immersion inlets, the direct cyl only has 5 openings. [DLMURL="http://www.newarkcoppercylinder.co.uk/cylinders/economy_7/"]Economy 7 Copper Cylinders | Newark Copper Cylinders[/DLMURL]
check the data plate on the cylinder as to its spec/type
Reply to the thread, titled "Economy seven hot water tank connections" which is posted in Bathroom Advice on Plumbers Forums.
