View the thread, titled "Electric shower + electric water heater" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
G
gijno
Hello, I'm looking to remove cilynder and tank from storage (I want to have empy space there not the cylinder) and I've found one solution on the web, I would like to know if it can be a good one or if it is faulty.
I live in a flat, electricy only, no gas, water pressure around 2 bar.
I would like to put this electric shower
Aqualisa Quartz Graphite Electric Shower 10.5KW
and to heat water for sink in the kitchen and sink + bidet in the bathroom I've seen this water heater (of course I'm gonna buy two of them, on for the kitchen and one for the bathroom)
Redring Powerstream 12KW
If I'm not wrong everything should be used with mains, isn't it? That means I can get rid of cylinder isn't it?
Thanks for your help 🙂
As you've been told, please get tradesmen in and talk to them, tell them what you hope to do.
In all honesty, given what you've told us so far, it's unfeasible, unworkable and downright dangerous.
We are actually all thinking of your safety.
Your best hope is to get a small unvented hot water cylinder fitted. A small 15l undersink unit will give limited hot water or if you can squeeze in a larger unit you can get them around 60 -70 litres. There is more flexibility in siting them as you don't need any cold water storage. They do need to be fitted by a qualified installer though.
Like this one?
Aqualoy SWSS - 7-15 Litre Stainless Steel Unvented Water Storage Heater | Redring
Which is the best brand?
Can I have two of them, one under the sink in the kitchen and one under the sink in the bathroom (this one shared between sink and bidet)?
That's the sort of thing. You'll need to speak to an electrician again regarding siting one in a bathroom, may need to go in a cupboard due to electrical regulations. They're all fairly similar as far as quality goes.
One more question guys... small unvented hot water cylinder uses water from the mains, isn't it? Actually I have a very good pressure for cold water (about 2 bar)... will I have good water pressure even for hot water?
Follow this link mate - [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
and post your request there remembering to include your location. One of the guys on here could be close to you.
Followed your link to this bidet, if this is the one that you have installed then you will not be able to have a mains water supply feeding it. (Water Regs 1999)
Hello Chris, thanks for your reply. I do not have installed any bidet yet, I'm still looking for the best solution. Can you please explain me your pic?
Reply to the thread, titled "Electric shower + electric water heater" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
gijno,
chris watkins,
