Hello, I am having my heating installed, the guys are using 10mm Polypipe from a manifold type setup.
We have couple of points where the pipe goes down a chased wall - is it ok to plaster straight over the 10mm polypipe - they tell me it's OK or should the pipe be embedded in trunking or is there a better way??
Aluminum tape can be used on the brickwork behind the pipe but not stuck to the pipe so the polypipe must be sensitive to wall coverings.
