ensuite toilet flushing but not draining away outside.
View the thread, titled "ensuite toilet flushing but not draining away outside." which is posted in Boiler Advice Forum on UK Plumbers Forums.
B
Barry1985
Hi, yesterday the walls in my utility room started making a loud noise (like next door were drilling) then i noticed the back wall was damp, i quickly turned off the stop tap and the noise stopped,
i went outside lifted the drain cover and got someone to flush every toilet for me, at first two toilets didnt drain but after my neighbour used a tool (not sure what it was) a giant collection of waste ran through outside,
i then thought the problem was solved, but today the noise started again in the utility room so i have flushed every toilet, ran the bath etc and everything is flowing through fine apart from the ensuite toilet, i can hear it outside at the drain attempting to make its way through but no visable water is coming past.
Strangley this time though the noise stopped when i turned the water mains off, but i turned it straight back on out of curiosity and the noise didnt come back.
Is this an issue i can sort myself or would i be best off calling a plumber? im asking on here as i can imagine call out charges on a saturday night to be high.
Thankyou for your help
(i did do a quick search on the forum but nothing came up to match my question)
Sounds like water hammer mate. You'd be best getting a plumber in. If you post up your locality then I'm sure someone on here would be available to help, also, post a new thread here -
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
i forgot to mention yesterday the carpet in the toilet next to the utility room was sodden with water, i have took the carpet off and its dry now and has stayed dry, the toilet and shower in there are draining away aswell.
Reply to the thread, titled "ensuite toilet flushing but not draining away outside." which is posted in Boiler Advice Forum on Plumbers Forums.
Barry1985,
Barry1985,
