Evaluation and feedback for new product required
View the thread, titled "Evaluation and feedback for new product required" which is posted in Independent Plumbing Course Feedback on UK Plumbers Forums.
I
iiplumbing
Hi Guys
After a long absence from these forums, I have gotten my newly invented product to pre-production stage.
The sample in the picture is called a T1 sample (first off the production tooling molds) T2 samples have already been made and are ready for installation evaluation purposes.
The product is patented, design rights and trade marked
As far as I can see it is the worlds first tundish with air break to drain and inbuilt sprung non-return drop valve to stop odours.
It complies with ALL the regs necessary and will be used in the under counter UVHWH segment of the market. It allows both a trickle rate of water (as little as 10ml of water is needed to open the valve) or full volume discharge.
Its primary use will be to enable the installer to connect directly from the PRV discharge to a local waste pipe to make the connection compliant. It is rated at 100degC
I am looking for 5 professionals who have undercounter UVHWH installations coming up in the next two weeks to have a product for free to give an evaluation and feedback and to build case histories.
Anyone who has questions please feel free to post or PM me. Also comments (positive or otherwise - but constructive please) are welcome.
When ready for sale they will be affordable and good value for money.
Anyone who has an UVHWH job coming up and wish to take part, please also feel free to post or PM me
Thanking you in advance
Regards
Russell
Hi Russell you would not believe what ive got in my shed....No only kidding all the best with your invention..brum
reasonable idea, but I would worry its got bits that seize, so would opt for a hepVo and normal tundish myself. however your idea should be a lot cheaper, so keep us updated
What's the connection on the bottom?
just finished 5 unvented electric heaters in some flats. Used hepv0 traps (don't know where they get the price from!)
yours would have been a good solution.
how reliable us the washer for not sticking ?(shut or open)
reasonable idea, but I would worry its got bits that seize, so would opt for a hep2o and normal tundish myself. however your idea should be a lot cheaper, so keep us updated
That may be a concern and the clearances of the shaft and guide are carefully designed to allow movement even with some build up of limescale. The moving parts are fully removable and as part of on-going maintenance (read an annual contract for the service of the cylinder plus now the Hot tun) the valve action is checked.
Price should be half of a standard tundish, Hepvo and adaptor, plus there is only on set of connections so installation will be quicker.......
Hope that helps
It takes a 15mm std tap connection inlet and std 22mm copper compression outlet.
Can a moving part stick? yes it could and what would happen if it did? The only time that would be a problem was when the PRV was discharging for safety reasons and it spilt out over into their cupboard instead of going largely unnoticed by the customer!
The spring is strong enough to ensure the valve never sticks open allowing smells to come back through.
It wont stick but if it did it would certainly mean that the customer would notice if the cylinder was malfunctioning
If the service engineer wanted to do a full volume discharge test he would make sure the valve was free anyway as part of his checks.
IMO
Russ
I feel a customer would be a bit ****ed if I installed something that flooded their cupboard, they would rather it went un noticed, which it shouldnt as the warning pipe should be visible, if it goes outside, as should the tundish in the cupboard. Now, if you produced something based on a combined hepVo and tundish at half the price, that would be a winner. Dragons den here I come.
Hepworth have the fanny trap patent all sealed up! ( so to speak)
Good luck with the venture, nothing is guaranteed never to fail and this seems to solve a problem. I'd be particularly interested to know if these could be used to terminate boiler PRV's into soil/waste?
Hi there russel, what ive noticed recently is how small the tundish,s are becoming , as time goes on they seem to shrink, but this one is consideribly larger which means offsets from the wall (if against the wall)
Im doing new builds (NHBC) at the moment that have 210l unvented tanks in them
Hi Nostrum
Thanks for your good luck!
I agree, when something mechanical is put in place there is always a risk of failure, but then valves stems fail and ruin cupboards (gate, stop and ball valves) etc
Just because there is a risk does not mean its not a good idea in principal.
It is my belief that my product will stand the test of time and you would have to "hold" one in your hand to get a feel as to the quality of the mechanism
Moving onto boiler PRV's. Yes they are suitable for that application provided that the Hot tun is located where a discharge can be noticed.
Russ
Its about 60mm dia. It has to be that wide to make sure the drop valve aperture is wide enough to accommodate a full bore discharge from the PRV.
On larger vessels space is not normally an issue and to be fair fitting the Hepvo is and always will be a valid and good solution (albeit more expensive) so the issue of offset is not really the issue here, because if you are going to run to a soil stack you will need either a Hepvo 50-55mm dia at its widest or my Hot tun at 60mm.
So the pipe at some stage will have to be offset anyway.
So if you fit my Hot tun to your cylinder you will not need the standard tundish or the Hepvo, and you can then connect to drain.
Hope that helps
Russ
PS I'm not trying to sell my product (at this stage) I am only trying to find some installers to help evaluate it and give some feedback once they have used it........
Hi Lame
Hope you are well. Thanks for the feedback and it is a valid point.
Having said that I have been to quite a few installations where the tundish has leaked because the joint (the joint that clicks the two halves of the tundish together) has failed and it has got the flooring all wet.....
So even standard tundishes can still cause problems
Its all a case of what you are prepared to accept, lets face it if you didn't want your house to ever flood/get wet then don't put water pipes in there at all!
Cheers
Russ
Wish there was. Can't understand why they are so much!
back to topic. If it's reliable, I think you have a good product there .
It is and thanks chalked
From my point of view I wanted something that was relatively compact and combined into one product (two jobs in one) the Hot tun is about the same height as a standard tundish (105mm tip to toe) and 60mm dia. And I wanted something that I as a poor plumber would be able to purchase at a reasonable price to make a mark up on and still be able to explain to the home owner they were getting a good deal.
Intro price of £15.99 plus vat with a customer price of £20.99 plus (you'll be able to get them through the merchant chains a bit cheaper than that anyway.
Russ
By the time plumb center puts there mark up on it it will be £159.99! Lol
My quick question I may just be being a bit stupid as always, if it was under counter heaters you were thinking of and going into the waste pipe why is it into 22mm and not 1 1/2"?
regulations state outlet from tundish must be at least one dia bigger than inlet
my website will keep the merchants honest, you will always be able to buy Hot tun off of the new website for £15.99 plus vat
russ
Haven't got any unvented installs in the next couple of weeks but interested in your idea.
good luck with it in the future.
Anyone want a free product to evaluate then?
Drop me a line or post on here
Cheers
Russ
Who's custard?
ok it's still not lost, do you get the concept of Hot tun?
can you put a few words down about how your installation would have been quicker easier if you had used it?
cheerz
Reply to the thread, titled "Evaluation and feedback for new product required" which is posted in Independent Plumbing Course Feedback on Plumbers Forums.
I
iiplumbing
I
I
MOSSEP
M
iiplumbing,
iiplumbing,
