everything ok but no hot water
View the thread, titled "everything ok but no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
G
gazza247
Baxi 105e boiler evrything is fine even the amount of water thru the hot tap but run cool, when exspansion on for hot water it starts hot and run quickly to cool. ANY Ideas please.😡
Is boiler main burner coming on when you turn hot water tap on,if so is it staying on when water running cold ?
Or when you turn tap on does nothing happen on boiler ?
need to explain yourself more for people to even hazard a guess
poss plate heat exchanger/poss divertor valve/poss microswitch as puddle said
what is burner doing when you turn the tap on
apoligies been away for the weekend, no the burner kicks everything is as it should be, it stays on. I have removed the micrswitch and mimiced it being still in place and pressed the diverter but still no luck as I said before.
Thanks for your responses.
be carefull when you start overiding your switches, make sure to put them all back before you leave job!!
sounds like the heat exchanger.
Reply to the thread, titled "everything ok but no hot water" which is posted in Bathroom Advice on Plumbers Forums.
gazza247,
Puddle,
