Do many merchants sell 1 meter long 3/4 male to 3/4 female. The 3/4 male screws in to the composite valve and the other end the expansion vessel. I presume came supplied with the composite valve. The flexi is leaking.
Screw that out and hard pipe it?I hard pipe them
Might be easier to use a male iron and a short bit of copper and a stnd 3/4 22mm flexi ?
Thanks it maybe hard to get the correct flexi. May solid pipeYou can do as it’s best but if you want you can use a flex
Is there anywhere on that picture where it states what size expansion is needed?
