hi guys. This is maybr a sizing issue but thought i would put it to others to get a second opinion. Went to service a boiler the other day then afterwards noticed that the water pressure was down to almost zero (sealed system) i repressurized and checked all rads were bled . All fine. left system running. Couple of days later got called back after customer stated water was coming out the prv on top of the expansion vessel. I checked over, and replaced prv, as common problem. I checked the pressure in the vessel and adjusted to Mi. Re pressurised and left. Now again its blowing off through the prv. So now im thinking that the vessel is NOT big enough for the system.
To clarify I only pressurized the vesssel to 1.5bar as per instructions. The water in system was pressured to around 1.5bar aswe... The vessel is an18litre vessel. There are 16 rads of various sizes. Most over 1200mm wide so quite a big system. All motorized valaves and pumps have been checked and the system has been power flushed so no blockages. As far as i can gather the customer said that the water pressure gauge has always been very low, so im thinking a problem thats existed for a while ??
Any opinions would be appreciated, thanks in advance
