paulusgg
Hi everyone,
I'm new to the forum and at the moment I can't find an answer to a problem I have.
I fit a lot of unvented cylinders for a loft conversion company (I'm G3 competent) as very often they need to see the storage tanks gone from the loft.
The question for you lot is "is it acceptable to place the expansion vessel at low level or should it be at least as high as the water control set?"
I've read some posts discussing the orientation of the vessel, i.e. Schrader (car tyre ) type valve pointing up, down or sideways, but nothing about the position of the vessel relative to the cylinder. Quite often, due to space limitations and servicing needs I've had to place the vessel at a low level, below the control set.
Thoughts and views welcome
