Sep 1, 2019
12
Heating Engineer (Has GSR)
If there is an unvented cylinder being installed in the loft,
System boiler downstairs, how would you decide what size expansion vessel to put on the heating side and how will you configure the Pipework for heating expansion vessel in the loft. As there will be an expansion vessel in the boiler so does it need another one.
And how would you decide if any pumps are needed as there is a pump already in the boiler.
Simply 1l per 1 rad unless there massive rads and a lot
Oversizing isn’t a bad point either it’s best
As for pump need to know a bit more about the sys how many rads standard house etc
Not installing but trying to understand for future references.
Let’s say it has 15 radiators, 3 floors.
