Sullivan
Hi Guys,
I would greatly appreciate somehelp in locating a modern close coupled toilet pan which has a horizontal outletlocated 210mm above the floor to the centre of the outlet – (205mm is theabsolute minimal dimension). Hopefully some of you guys have come across a panwith an unusually high outlet which I can purchase.I purchased a’ Denver’ toiletsuite from The Bathstore and the outlet on this particular pan is 185mm abovethe floor. My plumber installed the waste pipe too high and although I canrotate the Tee towards the horizontal, this causes the toilet cistern and thepan to be pushed more than 50mm off the wall which is unacceptable. (It wouldbe useful if pan connectors were available in increments of 10 degrees between0 and 90 degrees; - 60 degrees would be ideal for my particular predicament!) The ‘Denver’ is a high level panapproximately 475mm high and a similar high level replacement would be ideal aswe are over 6’ tall. I have already cut a wooden pedestal to place beneath the ‘Denver’,but I would prefer to put a pan directly on the floor as I think the pedestaldetracts from the look of an otherwise nice bathroom.Thanks,Regards,John.
