macka09
1,268
88
48
Hi guys. I need to replace a high level cistern/pan, for either a low level toilet or preferably a close coupled toilet. The big issue with this is that the 4in drain to it comes up through a concrete floor, which is 100mm from the back wall to the centre of the waste outlet in the floor. I can't seem to find a close couple toilet that has the required clearance at the back of the pan. Do any of you knowledgable folk know of a loo that may have the clearance I need? I've looked at wickes bog in a box but the pan would foul the drain when pushed fully back to the wall. Any advice would be great. Cheers.
If the pan is OK you can keep it and just fit a low level cistern, Thomas Dudley do a decent low level cistern with decent quality fill/flush valves for about £50
Use a vitra s20 or S 50 fully enclosed pan. The connection is 150mm back.
