www.tinyurl.com/SJB060685 (not the S model, but close - see section 11)I would like to see some literature stating it has to be that way
The position should be Vent, Cold fill, Pump and on the flow. The vent and cold fill should be a maximum of 150mm between centres, often the cold fill is brought down below the flow and then bends back up into it to prevent thermal drift. The reason the distance is 150mm maximum is because where the cold fill enters the system is the neutral point and you want the vent within this area.
There are other ways to position them but they are not ideal for system performance.
The above is the full proof way of do
Thanks man.That would be hot water creeping/rising up slightly through the cold fill. You will still have expanding water doing its thing but you're trying to minimise heat loss to the system load/loads, although it would be very little energy lost. I was always told to try and do it that way.
Your saying expansion vessel should be on flow so??heard its better on return coz its cooler..is this waffle??The cold feed on an open vented system acts exactly like where the expansion vessel tee's into the system on a sealed system. Google point of no pressure change and watch a video or two, there loads on there. You really do not want the pump discharging towards this neutral point, the videos will help you visualise why my friend.
May I ask you a question on slightly different topic?? Heating controls...??Ideally yes I would want it on the return as the cooler temperatures are less vigorous on the bladder. However, providing the position of the pump/pumps and vessel are right it will still function. Again though I personally would want it on the return.
Ok thanksYou can and I will do my best to answer
I think the line has become less strict on this forum now that it's international. He may well get the answer he wants (at least at the level he needs to know), but I think you've already covered it really - to me it sounds like oil boilers are much like gas, caveat that I'm not a Registered Gas Installer, so my knowledge on the latest models of gas boilers is limited.although you won't get that information on here if you're not gas certified.
