View the thread, titled "F22 error on Vaillant Ecotec Plus Boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi Last Plumber, thanks for your reply. I'm not sure what a PCB is? Six months ago the system stopped working and the person who serviced my boiler (who I can't get hold of) replaced the silver box that was there with one he had in his van (see attached photo).
Thanks for your reply Dan. I found a youtube video of the exact same pump (same 59525600 part number) -
And it shows it easily spinning. Mine does not budge at all.
Update: I removed the screw on the front of the pump again, and the screw inside still would not budge. So I used the screwdriver and a small hammer and tapped a few times. I could feel it was moving a little, then I put the screwdriver in the center and I was able to move it more. I then put the central heating on and turned the screwdriver a couple of times and I could feel the motor going. I then put the outer screw back on.
The heating has been working for the last hour or so and I have hot water and heating again (for now anyway!). Thank you again everyone so much for your help!
What do you recommend I do now? Should I consider replacing the pump, or leave it. How long is the pump likely to last? The central heating system was installed around 7 years ago.
Reply to the thread, titled "F22 error on Vaillant Ecotec Plus Boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
