I
ianm
I need to replace the back nut on my hot bath tap. However, the gate valve on the cold water supply to the HWC seems to have failed and still allows a flow through the hot tap even when closed. I live in a flat, presumably with a shared cold water tank somewhere in the loft to which I don't have access. Is there any way I can stop the hot water supply to do this repair? Or failing that, is it a terrible idea to disconnect the pipe to the hot tap with the water still flowing slightly, quickly replace the back nut and reconnect the pipe?
Thanks,
Ian
Gas. The trusted advisors are that for a reason. Please don't accuse them of giving daft responses or scare mongering on a thread such as this.
The OP would be best to get a plumber in as advised. And snatching in this scenario is most certainly not to be advised.
OP here, thanks for all the replies. They were all very helpful and I can understand the different points of view. My feeling is that as a DIYer I most probably could manage to do the job, but just to guard against the small chance of something going horribly wrong I should this time get in a plumber and also get the faulty gate valve replaced, so that next time I CAN do it myself.
Cheers,
Ian
P.S. Some kind of hinged or two-piece back nut would indeed solve the problem, but my googling failed to find any such thing.
Ian, as you are obviously interested in achieving this (hats off for that), why not speak to whoever manages the freehold etc and find out how to access the tank - they really should facilitate that and you'll probably find your plumber might want to anyway.
Would this not be a perfect situation to use one of those new clamp on replacement lever valves? Would allow you to issolate the cold supply to the hot tank that the faulty gate cant. Golden rule of plumbing "isolation" fulfilled and work can comence with gusto.
It would if they were available in 22mm. As far as I'm aware they only make them in 15mm at present.
That I did not know. I guess 22 is just too hard to crush down away from the valve insert when its been cut. either that or they just haven't released it yet. Seems strange to have a potentialy game changing product but only offer it in a 15mm size.
