H
HughCallaway
I hope that someone can help me and point me in the right direction.
My central heating has recently stopped working from coming on by the room thermostat. I thought the issue might be a dodgy thermostat as I managed to get it working every now and then by switching off the boilers electrical supply and turning up the thermostat to the max. I've replaced the thermostat but the problem still exists.
What I then did was to switch off the hot water on the programmer and the boiler started and central heating came on.
I've looked at the wiring and now wonder if its the Drayton Mid Position valve or maybe the programmer. Does the Drayton Mid Position valve control the electrical supply to the room thermostat?
I realise I might need to get a plumber in but would like to try and understand the problem first.
Any help would be gratefully received.
Hugh
Hugh
