View the thread, titled "Ferroli Combi 77 FF P boiler problems" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
ChrisReed
I have a Ferroli Combi 77 FF P boiler. For some time, it has been running for a few minutes/seconds, then cutting out, before restarting. The result is that we are often without hot water or heating.
Two engineers have told me that is because the water pressure is below 1 Bar (it is consistently showing 0.6-0.8 Bar). The mains flow was very low, so I have had a new main installed by Essex & Suffolk Water. The flow is now very strong, but it has had no effect on the boiler. I now see from the instruction manual that the boiler should be topped up with water (something none of the engineers have suggested).
Can someone tell me where to go from here, please?
you need to find an engineer who know their stuff Im afraid as if its worked previously with low water flow then it should still do so, so its an issue with the boiler still
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Ferroli Combi 77 FF P boiler problems" which is posted in Boiler Advice Forum on Electricians Forums.
