T
tomwykes
I'm Tom, a Handyman by trade. I'm trying to diagnose a problem with my Ferroli HE31 C. I know the problem was buying it in the first place, but I'm stuck with it now.
The fan runs constantly, I've changed the flue sensor but that did nothing.
The boiler makes all the right noises and can be made to work by flicking off then on the mains plug. However once it reaches temp and cuts off it then just won't light again without the switch trick. the LCD shows that it thinks it's on and if there is DHW demand, it even makes all the right noises right up to the firing bit. There are NO error codes on the screen.
It has a new mother board as of today but this solved nothing. SO it's either the fan module (not sure how to test this) Or my wife has changed the TS code by button pressing. Does anyone have the TS code sheet that I could study to see if any of the perameters have be changed?
Any help or advice would be welcome.
If I can't sort it out I'm going have to bite the bullet and have it swapped, I'm eyeing up the Alpha CD50, can anyone recomend that boiler?
Tom.
Tom.
