View the thread, titled "first attempt at plumbing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello and glad to find this site and I'll have a lot of questions to ask.
My first question is regarding basin waste pipe,am I on the right page?
jinty
Welcome!
1 1/2" is big for a basin. It's normally 1 1/4". The mm sizes are pretty much the same.
32mm - 1 1/4"
40mm - 1 1/2"
be aware that there are two types of waste pipe, for example,
1 1/2" push fit is a different size to 1 1/2" solvent weld!
a compression waste fitting would resolve that.
are you swapping the pipe or the basin, or both??
welcome along
Thanks lads for your answers. I had bought the wrong size connections (40mm/1 1/2) and took along the solvent connection I had cut and got the similar connections (32mm/1 1/4).
I'm replacing the basin which is a different height and distance from the vertical drain .
I also met a plumber at the store who advised me and gave me a short length of pipe to do the job! It's great to meet people like that I asked for his card in case I give up DIY.
Thanks again
Thanks again
Thanks for getting back to us, good luck and take your time and it will all come together in the end.
Reply to the thread, titled "first attempt at plumbing" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
None
jinty,
Ch4 plumbing,
