First Year Apprentice Tool Kit Questions
View the thread, titled "First Year Apprentice Tool Kit Questions" which is posted in Plumbing Tools on UK Plumbers Forums.
B
breach
I just got myself a plumbing apprenticeship after a LONG, long search. I already had a few things, and know that I'll need to pick stuff up as I go, but to start off with, do you think this is ok? The guys Im working with all have massive kits, and then even more in their cars and at home. Ive found good use for all of this stuff so far, and I know I'll need to add some tin snips and pipe wrenches and adjustable wrenches. Anyone think of anything else though? Also, how many different sizes do you get for your adjustable and pipe wrenches? One site I was on seems to suggest having 3 sets of adjustables in 6/10/12" sizes, and pipe wrenches in 10/14/18" sizes. The company Im working for provides all the power tools I require
Tongue & Groove Pliers x2
Multi head screwdriver
Measuring Tape
Hack Saw
Utility Knife
Flashlight
Level
x2 300mm adjustable spanners
Water pump pliers
mini Power screwdriver
x2 short screwdrivers (for hard to get at things)
15mm pipe slice
You can do most things with this set of tools - mind you dont forget the other hundred you get to use once or twice a decade!
Dont fok around with the full spanner set it probably aint worth it !
The thread mentioned is a good starting point, with Mushybees kit being a good one to get.
As for having a kit without tapemeasure, hacksaw, basin wrench, blowtorch, Mehera are you sure you do plumbing ?
When asking for advice Breach make sure it comes from a reliable source, but then having gained an apprenticeship,(congratulations by the way), I am certain you have sufficient brain power to work that one out😉
Yeah by the way I recommend that you dont waste your time on an apprentiship like razal. Go go fast track, thats the way to do it today!!!
Unless you want to spend 4 years making tea for a clapped out fossil like 'BJ'!
Or become a doctor in the same time!
Cheers, thank you for the advice. I talked to one of the guys at work, and he said the key is to buy stuff gradually. Apparently a lot of apprentices go out and buy a bunch of stuff right away when they cant really afford it, and they end up using some of the stuff once a year. He said that for now, what Ive got is all I'll need, but to add a 5/16" ratchet to my kit. Im going to get a pair of adjustable spanners too, since I know I'll need those in the future.
As I say, reliable info is required, sort out the wheat from the chaff.
Mehera only makes tea for himself.........all day cos he aint got anything else to do .😀
It makes good sense.
I used my employer's tools for a while but go tired of having to leave what I was doing to go get a tool only for him to call out for it minutes later.
I'm glad I got my own kit together though because I was soon given more responsibility and doing work while he wasn't on site.
The best advice is to get good quality tools when you need them. Buying cheap stuff is just a false economy as you'll invariably have to replace them much sooner.
That said don't break the bank on things like screwdrivers because you will loose a couple no matter how dilligent you are.
dont take any notice of this guy hes obviously bitter about not being a city and guilds plumber and his description of the required tools for the job are laughable and sound the pearls of a DIY king
lol an apprenticeship is not a waste of time this guy has obviously been sniffin solvent weld 😛
1st years dont need much tools but i'd suggest a tape measure, hacksaw, 2 shifting spanners that can go up to 22mm, pair of grips, cutters, blowtorch
although i didnt start buying most of my kit until 2nd year, used the tradesmens tools as they didnt expect you to go and buy tools with the money you made at the time.
well said!
I thought all apprentices needed was a kettle and a ready supply of teabags, milk, sugar and water, not forgetting ear defenders for all the rockets theyre gonna get fer forgetting the all for said items everyday!!!!!!!!
P.S. they are not called apprentices for the first year, they are all loveslaves
harsh! 🙂
some good points in these threads though.
i've got a fair amount of my own kit already. Its been tried and tested too.
the plumber that came to my house even borrowed my bender and blow torch.
gaining a bit of experience bit by bit and have photos of my work so far.
learned a lot in the process and am accumulating the tools as i come accross the need for them.
as a school leaver you can learn alot from just being around trades people and building sites. its 4 years for a reason, often the first year is learning the social skills to get along with adults after being in the school system for year. learning what the names of fittings and tools are etc. it obviously builds on this year after year until your final years you should be doing alot of your own work under supervision.
the year 5 its crikey, im on my own ,,heeeeeeellp
I think a lot of it being so long is that the original purpose was for college students etc.
Not saying their rate of learning is any different to the rest of us but realistically if we think about how often most of us use our algebra, literature, languages, basic mental mathematics and other things, the answer is probably NOT MUCH.
This may be way off base but even the comapanies offering fast-track are providing information, books, manuals, cd's, scenarios and such like. This takes time to read, understand, retain and apply.
My main point is that even though it might be advertised as fast track or such, i doubt many individuals will do it quickly at all.
Then of course there's the NVQ parts, work experience, customer building, personal skills, paperwork etc.
I doubt i'll get through the first one inside a year (even if i had 24/7 to do it)
Its tha same as when IT was booming, most perms went off contracting for the money, a load of new blood suddenly joined in with little skills, a weeks course and a multiple choice exam to their name and hey presto , they were suddenly making good money and causing grief for people like me that came up the long route.
I understand all peoples feelings on here.
I just hope to be one of the lucky one that gets given a chance nearer the time.
Inmy honest opinion one of the most valuable tools that all apprentices should be given is a Mason Master Rawl Plug Jumper, the older guys on this forum know what I mean as it has been discussed before, It is a truly cordless drill that was used before battery operated drills came along but if you wernt carfull you would batter yer hand to bits with a lump hammer that way these young whipper snappers can respect what us oldens had to go through when we where apprentices.
I remember wheni was a lad we had to get up at the.............................................zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
the long weight
box of sparks
stripey paint
left handed hammer
left handed anything really
sky hooks
ive heard them all and fell for a few when i was young and on site.
to be perfectly Honest we keep forgetting the truly most important tool in our arsenal which is ourselves, with loads of trainning, experiance and unforgettable or unforgivable mistakes we slowly develop our selves into weapons of mass construction.
So all you loveslaves out there be nice to the grumpy old gits out there, cos they is yer best allies
Reply to the thread, titled "First Year Apprentice Tool Kit Questions" which is posted in Plumbing Tools on Plumbers Forums.
breach,
PlumbBobBob,
