View the thread, titled "Fitting close coupled pan/cistern to floor mounted soil pipe?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
chrisab
I want to use the concept Ideal Standard toilet (specs below), the existing soil pipe comes up through the floorboards and is flush against the tiled wall. Will the concept toilet fit? I also read that the flush with wall version of the concept toilet (pan goes back flush with wall) doesn't work with floor soil pipes - is that correct?
Anyone also know of a good wall mounted mixer diverter that will either divert water to a shower head or into a bath through a overflow filler?
Hi, it looks like it will work, and with back to wall one you could maybe use flexi connector ?? depends on how far outlet sticks out
imo
If your soil pipe is coming up through the floor,flush with the tiled wall as you say it should fit Ok
imho
[DLMURL="http://www.grohe.co.uk/p/25_103261.html#!i103261_1115,p(p19399G017),d(s1"]GROHE - Product range - Atrio Jota & Ypsilon - Bathroom Faucets - Bathroom products[/DLMURL])
Would this be of any use?
mcalpine do a catalogue of a wide range of fittings ask your suppliers if they have 1
Reply to the thread, titled "Fitting close coupled pan/cistern to floor mounted soil pipe?" which is posted in Boiler Advice Forum on Plumbers Forums.
