fitting my shower bar mixer practice run questions
View the thread, titled "fitting my shower bar mixer practice run questions" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
hi all
i hope you are all well
i'm planning to install my shower mixer on Saturday. today i was doing a dry fit and i wanted to show you some photos and questions. i'm using fast fixing brackets. i was wondering what length do i cut the pipe to? also my shower bar mixer has these cone shaped water inlets ( i don't know the terminology) if i was to dissect it, would these "inlets" be up against the pipe. ( I do have pipe inserts)
any advice, tips will be appreciated
thanks
finest
Your photos look about right, as long as you have the Hep2o insert for the pipe, ie 3 or 4 mm past the olive.
The cone thing looks like an inlet filter to me but it feels like it’s the wrong way around? Check the instruction.
If the filter is not compatible with using hep2o ( has a smaller internal diameter than copper) then you could throw them away and use a rubber 3/4” washer that incorporates a mesh filter to connect the valve to the fastfix .
A lot of showers come with these anyway, if you need to buy them they are called appliance or hose filter washers 3/4” - and are for washing machine inlets.
thanks for your response. yes these "cone" filters screw off. i unscrewed it earlier this evening. i do have the rubber washers but not with the gauze in the middle. i have to check properly. i originally had a 3/4 reducer which the filters fit nicely in. i take it it will work fine without them
Yes it will work, but if debris gets into the cartridge that can be a real problem.
So; flush the pipes through properly before you connect the valve, and get the washers with the gauze filter.
dear all, i would like to wish you a happy new year. I would also like to thank you all that have helped me repair this shower. i managed to get it all done before Christmas. i honestly could not have done it without your advice and tips
thanks
Finest1
Reply to the thread, titled "fitting my shower bar mixer practice run questions" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
finest1,
finest1,
