View the thread, titled "Fitting of external oil boiler correctly" which is posted in Boiler Advice Forum on UK Plumbers Forums.
If the pipes are lagged through the wall with Armaflex insulation, whether sleeved or not, it will probably be fine, especially if a dry wall.
But, to throw a spanner in the works, - mice can easily get into the house by simply chewing through the Armalex!
Actually better to leave the last bit of pipe bare & just use insulation tape on it & then weak sand & cement to fill the gap, so to stop mice!
Reply to the thread, titled "Fitting of external oil boiler correctly" which is posted in Boiler Advice Forum on Plumbers Forums.
