Breach of gas act can be criminal.
Failure to meet building regs is civil.
Isn't gas regs just a statutory instrument - secondary legislation / reg. think they all fall under the Building act 1984? That's what you go to prison for?
Not my area of expertise, but I thought that all the statutory instruments merely amended or interpreted the core gas acts - 1986, 1995 etc.
Yes believe so but gas regs was brought in to satisfy building act requirements ?
You could be right Guy.
But its actually a criminal offence to do gas work without the relevant approval. Thats a very different thing to not burying a water main deep enough, or failing to upgrade to part L spec.
Breach of gas regs (Stautory Instrument) could lead to a criminal offence. So? second hand boiler? Manufacturer instructions available? but may be not compliant with building regs also a criminal offence.
But building regs (building act 1984) is above gas regs . That's why gas safe can't chase a non registered muppet but labc can.
Gas regs are above building regs in the legal world.
Ay? A statutory instrument is a lesser bit of statute compared to an act? Buildings act is where it all comes from??
Statutory Instruments - UK Parliament
A matter of interpretation. The act goes into finer details to support the breach of the statutory instrument, therefore prosecution cases use the act to support contraventions of the statute.
yes gas regs override building regs they dont however overide MI,S
I was referring to the buildings act - which is where all the regs are derived from / for? Gas regs, building regs, water regs..... Yeh see that gas is over building and so on.
Mi's are the same level as building regulations, they give the detail to support breach of Gas safety regulations.
To summarise, Statutory instruments rule above all.
However, when referring to an OIL boiler.........
Any of you clock what forum this is in?
I was always told if it's A rated and has manufacturers instructions you can. Iv refitted a rated combis before
I would assess the situation and decide from there. I have had instances where I have said no and one instance where I have done it.
Thanks Croppie, for pointing out what should be the obvious. Back to Topic, my interpretation is, if it's a HE Boiler LLD or Balanced flue then OK as long as installation complies with BS5410, Part J and of course Part L1b. If its SE or open flue, far too much trouble.
Just because someone else fits them, doesn't make it right.
Any S/H boiler decommissioned and standing empty is corroding internally.... so my advice is leave it alone and protect your reputation as a honest professional tradesperson (PC)
Reply to the thread, titled "Fitting secondhand boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
