Hi, just flushed a system today, water looked more like crude oil.
With the system filled and curriculating I had had a quick look to see if I could spot any leaks that might be drawing in air. No sign of anything but the aav was making noise, it was as if it would never stop letting out air.
Now I'm thinking it could be sucking it in, it's on the flow coil and the pump is on the return coil.
Really unsure about this system, oil and range into a twin coil cylinder, seems like they've capped one open vent and then slapped on a blow valve with not even a pipe turned down
