A
ahides
Hi all I have a flame failure problem on my Baxi 105e approx 7 years old.
A few days ago we started getting intermittent hot water which then stopped completely, 30 degree neon flashing indicating flame failure, turned reset switch and fan would come on and try to light burners but would cut out almost immediately briefly lighting the 80 degree neon and start 30 degree neon flashing again. Same thing happened on CH demand.
Replaced both CH and DHW temp sensors, (DHW showed signs of limescale), cleaned diverter valve and inspected DHW pressure differential diaphragm, this was ok but getting weep out of push rod nut at front. Cleaned out cold water inlet filter and reassembled.
When I reassembled I noticed some moisture around the on/off reset switch, dismantled the switch and thoroughly cleaned and dried.
From switch on I immediately got the same fault (30 degree neon flashing) however now when the reset is turned the boiler fires up and works perfectly on both CH and DHW demand but the fault reappears if I let the boiler stand for a period of time, again I turn the reset and it works perfectly.
Also on DHW demand pressure gauge jumps up approx 0.5 bar? Don't know if this is even a problem or if it is a problem is it related to the above, or a completely different fault?
Any help appreciated
