A
ahides
Hi all I have a flame failure problem on my Baxi 105e approx 7 years old.
A few days ago we started getting intermittent hot water which then stopped completely, 30 degree neon flashing indicating flame failure, turned reset switch and fan would come on and try to light burners but would cut out almost immediately briefly lighting the 80 degree neon and start 30 degree neon flashing again. Same thing happened on CH demand.
Replaced both CH and DHW temp sensors, (DHW showed signs of limescale), cleaned diverter valve and inspected DHW pressure differential diaphragm, this was ok but getting weep out of push rod nut at front. Cleaned out cold water inlet filter and reassembled.
When I reassembled I noticed some moisture around the on/off reset switch, dismantled the switch and thoroughly cleaned and dried.
From switch on I immediately got the same fault (30 degree neon flashing) however now when the reset is turned the boiler fires up and works perfectly on both CH and DHW demand but the fault reappears if I let the boiler stand for a period of time, again I turn the reset and it works perfectly.
Also on DHW demand pressure gauge jumps up approx 0.5 bar? Don't know if this is even a problem or if it is a problem is it related to the above, or a completely different fault?
Any help appreciated
Lol thats a no then... Hes opening up boilers without his gas therefore BREAKING THE LAW and endangering others.
Theres quite a few that do this and they always only have 1 post (this one)
Get yourself someone who knows a bit about boiler repairs ahides 🙂 Guessing at something that has nothing to do with the issue just costs you money IMHO 🙂 Flame failure could indicate something simple or potentially dangerous hence the reason why the boiler is shutting down.
Get diamondgas in! Hes awsum at boiler repairs! I dont like it, my patience wears thin! Prefer installation
Perhaps I didn't explain myself properly, I spent 20 years as a kiln engineer, and I don't wish to appear rude but the type of gas equipment I worked on makes your daily bread and butter boilers seem trivial in comparison. Insofar as breaking the law goes if you were as clever as you claim to be you would know that repairing and replacing of water carrying components and electrical components can be carried out by other competent personnel, which I am having worked on electrical systems for many years.
You should also know that for the last 15 years I have been a NEBOSH qualified Health Safety and Environmental Advisor and am fully versed in the law and legislation pertaining to this and a host of things I am guessing you would not have a clue about, nothing in my thread mentions anything about working on any gas part nor opening the combustion chamber.
I had hoped that someone more knowledgable than me about this type of boiler would give me an indication of what was wrong to enable me to decide whether to call in a repair or just have a new one fitted, I didn't expect the self appointed "Boiler Police" to take a cheap jibe at me.
If there is anyone who can let me have their wisdom I would still be happy to hear, if not I shall bid you all good day
Regards
Lol its ok diamondgas, thats the best way. As for this guys claims, where did i state i have loads of knowledge? Baxi 105's have loads of faults, just replace it especially if its 7year old, wont have much life left... Think what you like dude 🙂 what area are you in uk? Maybe someone in this forum can help you out thats close?
Regards
So you know a bit about stuff but know also when to turn to the pro's when you're not sure yeh? This site gets pounded by less knowledgeable folk alas who can access open forums such as this! Professionally I try to limit my sharing because of the potential implications should someone less able be reading this! I hope that makes sense?
Flame failure issues can arise from simple aeration to more complex visciation, electronic detection or earthing issues! Honestly I'd get some one in or better still on to an annual contract with one of the bigger fish who can come out and swap willey/nilley parts to get to the bottom of intermittent faults 🙂
Reactions: 5 people
the phrase i dont wish to appear rude is used by rude people who dont wish to be completly honest i could being a trivial bread and butter boiler fixer offer some advice but my humble suggestions would not be worthy of your exaldated consideration the trival await your stinging reposte with quaking knees
Reactions: 2 people
Sometimes the phrase "I don't wish to be rude" is made by people who really don't want to be rude but perhaps have been a little upset by someone's smart, uneducated, and unnecessary comments, having started my working life sweeping the fabrication shop floor I have no airs and graces about myself I assure you. I may have been guilty of responding whilst annoyed and if I have upset anyone else with that I apologise it was not directed at anyone else, I value anyone who has anything positive to offer.
Diamondgas, Thanks for the advice, you are right, one of the points I try to get across to people in my training courses is that competence is not about knowing everything, its about knowing when you need to ask, your comment makes perfect sense, i will probably go for a new boiler, maybe an Ideal Logic they are offering 7 years at the mo I understand? any advice welcome
it was good of you to reply honestly and i too apologise sarcasm isnt attractive no matter whose doing it but weve always been very friendly towards each other on here and when someone appears condesending we close ranks not pretty but it comes of appriciating each others knowoledge of boilers
Just installing a logic+ heat only into my own home ahides 🙂 The warranty is what attracts me because whatever you purchase is likely to go wrong! 7 yrs isn't a bad guarantee in my opinion and a lot less expensive than those who's rely on past reputations!!! ... Time will tell to be honest 🙂
By the way, buy the 30+ as the 24+ is not worth it unless your water supply is pizz poor 🙂
get the 105e repaired they are superior compared to a logic,i am not going to comment on the rights and wrongs of you trying to repair your own boiler but as i am sure your aware you cant touch the gas or flueing side of things,my advice to you would be either find a competent engineer to sort out your issues,or get a one off repair done with heat team baxis own personnel,you will regret having a ideal IMHO the 105 is the best combi ever produced
Time will tell Mark, your thoughts towards Ideal may change.....? 🙂 ... I agree the 105e are relatively trouble free and a good boiler 🙂
I'm going to comment on the rights and wrongs of him trying to repair his own boiler. It's arrogant to come on here asking advise on a gas appliance, and then jump all over someone who points out it that it would be sensible if you were to use a qualified, COMPETANT, and 'Gas Safe' Registered engineer.
You may have done lots of wonderful work as a kiln engineer, but if that doesn't directly relate to a modern, domestic boiler - then frankly it isn't worth a fart.
The fact that you have spent the last 15 years as a health and safety advisor (and not working on gas appliances) proves to me one thing.....that the regard the general consensus hold of 'health and safety advisors' is well placed.
Now I will bid you a 'good day'.
Reactions: 3 people
UK Plumbers Forums
Deleted member 120897
